oil pressure
Old Mar 4, 2013 | 09:09 PM
armmata's Avatar
Default oil pressure
i have an 1995 accord with a 2.2 vtec auto i just replaced the head and water pump time belt and everything else your suppose to do and just took it out for a drive and the darn thing runs great no problems at all no heating up or anything to tell me that i goofed but my oil light started flashing on the way back then just stayed on and the dran thing still runs great. so can anyone help with this light
Old Mar 4, 2013 | 10:17 PM
NZXTInerTia's Avatar
Default Re: oil pressure
I would help you, but I have no idea (please tell me if I'm alone here) what you just said/asked.
Old Mar 5, 2013 | 12:20 AM
armmata's Avatar
wow smart butts like your not new
Old Mar 5, 2013 | 12:41 AM
Erikthetech's Avatar
check your oil level first.. check ur Oil Pressure Sender Unit.. make sure you have no major oil leak. and if it still on then i wouldn't drive it and get it to a mechanic
Old Mar 5, 2013 | 03:46 AM
JamesB1985's Avatar
I agree with Erikthetech but would also like to add do an oil pressure test with a gauge - if you dont register any pressure on the gauge when you start the car turn it off immediately and fix the problem - i.e. - blocked oil filter, blocked oil strainer, oil pump problem.
Old Mar 5, 2013 | 08:25 PM
armmata's Avatar
thank for the advice guys hey smart butt get a life
Old Mar 5, 2013 | 10:15 PM
lol Are you kidding? A more refined statement or question can be answered by a more detailed and helpful answer.
Old Mar 6, 2013 | 05:27 AM
GhostAccord's Avatar
Learn to type a coherent question, with the use of punctuation, and you might get an answer.
Check oil light..... maybe check the oil? If that doesn't work check the pressure sensor and the actual pressure of the system. That being said. Where you are asking what to do when the oil light comes on. I'm guessing you have no idea how to test the wiring or the oil pressure. Therefore, I would suggest that you take it to a shop for further diagnosis.
lonewsome
Jan 1, 2009 01:42 PM
eric416
Oct 9, 2008 04:03 PM
hatchedeg
12
Feb 2, 2008 10:55 AM
BACKintheDA
Jul 12, 2005 01:05 PM
elnoyl
May 19, 2005 04:54 PM
