idle problems?
Old Mar 4, 2013 | 02:12 PM
EH6jade's Avatar
Default idle problems?
hey wats up guys i have a 95 del sol and it doesnt like to start up right away takes like 2 or 3 times to start and i gotta give it some gas but after that it runs but idles below normal does any one know what might be the problem?
Old Mar 4, 2013 | 02:27 PM
Crxxxing's Avatar
Default Re: idle problems?
you try adjusting the idle screw on the throttle body?
Old Mar 4, 2013 | 04:37 PM
datsol94's Avatar
Do you hear the fuel pump prime when you put the ignition to on? Do the lights dim when cranking or does it sound weak/slow?
Old Mar 4, 2013 | 04:40 PM
dazebreak's Avatar
you check the tech faq sticky in this forum? lots of good info... check & clean throttle body, iacv/eacv, facv, plugs, wires, cap , rotor, battery, alternator..
Old Mar 20, 2013 | 03:40 PM
EH6jade's Avatar
Yes the fuel pump comes on and it wants to turn over but just doesn't want to start till like after I crank it up 2 to 3 times
Old Mar 20, 2013 | 03:44 PM
gabriel0830's Avatar
im having that same problem on my 1994 honda civix sedan and i tried changing fuel pump nd battery but nothin works
Old Mar 20, 2013 | 05:25 PM
Eglifehomie's Avatar
I'm having a similar problem and will replace the iacv this weekend. Ill let you know what happens
Old Mar 23, 2013 | 01:44 PM
datsol94's Avatar
Whens the last time you did a tune up? Plugs, wires, cap, rotor, fuel filter, air filter, etc.
attz0r
Feb 15, 2014 04:03 PM
DAtegLs
Dec 10, 2009 01:58 AM
Mad Third Gear Vtec
Mar 25, 2009 09:20 PM
wanderinglost
Nov 7, 2008 08:31 AM
myRice
Nov 20, 2005 11:45 AM
