grounding kit
x2!!!!!
if you're gonna replace your ground wires, mine as well upgrade to thick car audio wire, since thicker wire means less resistance.
4 gauge is the most you'd need, 0 gauge is over kill. also, it would help to wipe down the grounding points to make sure there's no dirt, then get sand paper and sand it down to bare metal so that you get the best connection.
Jsracingintegra
Oct 30, 2002 06:29 AM
