obd2 vss vs. obd1?
Old Mar 4, 2013 | 11:17 AM
Thee_Antic's Avatar
Default obd2 vss vs. obd1?
Very long story short, 1994 del sol b16 swap, swapped out my broken down b16 trans for another b16 trans out of a 2000 si.
The vss looked different on the new one, but I figured since it had the same plug it would opperate the same. Well I'm throwing a vtec code and what a coincidence, I have no vtec. Guess I was wrong.
I'm assuming I need to go back to the obd1 type sensor. Any chance someone knows the part # off hand?
I'm not crazy thinking this is problem am I?
Old Mar 4, 2013 | 11:29 AM
kyden's Avatar
Default Re: obd2 vss vs. obd1?
they work the same. make sure the pins on the VSS aren't corroded.
Old Mar 4, 2013 | 11:35 AM
Thee_Antic's Avatar
Dammit. I was really hoping that was the issue seeing as they looked completely different. Now that I think about it though I would be experiencing speedo issues if that were the case would I not?
Old Mar 4, 2013 | 03:01 PM
94EG8's Avatar
Seagull Management
Yep. The VSSes do operate the same though, I've swapped one for the other lots of times.
Old Mar 4, 2013 | 03:19 PM
Thee_Antic's Avatar
Thanks you two.
Just found out my tps is bad, so maybe thats the culprit behind this vtec issue.
im a monster hehe
Jun 18, 2006 04:09 PM
Jason703Racing
Mar 28, 2006 07:13 PM
sqwale
Oct 10, 2005 12:21 PM
