97 accord flooding, won't start
Old Mar 3, 2013 | 01:20 PM
supraqtech's Avatar
Default 97 accord flooding, won't start
Hi,
I have a 97 accord that won't start, it appears to be flooding. If I remove the injectors it will run until it burns available fuel then dies. If I introduce more air by disconnecting vacuum line to brake booster it runs wide open. where should I be looking, I am getting no codes, I disconnected the tps and it threw a code, Plugged back in and it didn't. What controls the amount of fuel delivered on start?
Old Mar 4, 2013 | 03:04 PM
fcm's Avatar
fcm
Old Fart
Default Re: 97 accord flooding, won't start
The ECU/ECM controls injector pulse, either the ECU/ECM is bad, one or more injecter is bad, one or more of the leads running from the ECU/ECM to the injectors is shorted to ground keeping the one or omre of the injectors open. 94
Old Mar 5, 2013 | 04:00 AM
supraqtech's Avatar
Thanks for your response, I have already tried a different ECU, injectors are not leaking, they all seem to be opening for the same duration so I will check for ground. If I crimp the fuel supply line I can get the car to start and run, albeit not well. I was thinking possibly too much pressure and I have a gauge but no way to connect it since the 97 doesn't have a sevice port. any ideas on how to connect one? I have checked the regulator for leaking to the vaccum side and it seems ok.
Old Mar 5, 2013 | 06:20 AM
fcm's Avatar
fcm
Old Fart
Replace the FPR, it sounds like it may be stuck wide open. 94
Old Mar 5, 2013 | 09:02 AM
supraqtech's Avatar
Thanks, I'll try that next
Old Mar 6, 2013 | 11:53 AM
E4usmc's Avatar
Yeah I had a 97 accord with similar problem and I change the fpr and it solved the problem
Old Mar 7, 2013 | 04:53 AM
supraqtech's Avatar
Just want to say thanks for the help. I now know what the problem is. After changing the fpr and still having the same problem, I started thinking timing again so I double checked the cam gear and it kinda looked like it was in between teeth, so I advanced it one, rotated a couple revolutions to make sure it stayed. I put it back together and it fired right up idling perfect, and then what ever made it slip the first time happened again. Only this time it wasn't just one tooth. I put it back in time and now I have zero compression on all cylinders. Don't know how I could have bent every valve but, I guess now I am pulling the head. Again thanks for the help especially to FCM
supraqtech
Mar 5, 2013 06:26 AM
Tedrowfire
Dec 24, 2012 10:39 AM
dog45us
Jun 2, 2012 03:26 PM
SIR_DREAM_KID
Feb 22, 2012 05:26 AM
