Performance chips
Whats going on guys, i have a quick question, i have a 1997 honda accord ex v6 and wanted to put a chip in, i need help in deciding which brand is the best because i dont want to put anything in my car to mess up the cpu. Thanks and i appreciate the feed back
There really aren't any chips that will do you any good, at least nothing you will feel. At least not for our cars, you could try getting a chipped ECU with a stock basemap (I presume your car is stock).
These plug and play chips that are being advertised are worthless.
Where you are running a V6... There aren't any OEM V6 ECU's that can be chipped and tuned. You will require an aftermarket engine management system/ ECU.
Downgrading to OBDI isn't too difficult and opens up the availability of using OBDI chipped and tunable ECU's
smokin rubber
Dec 21, 2002 11:54 AM
