Performance chips
Old Mar 3, 2013 | 07:28 AM
Kevin2890's Avatar
Default Performance chips
Whats going on guys, i have a quick question, i have a 1997 honda accord ex v6 and wanted to put a chip in, i need help in deciding which brand is the best because i dont want to put anything in my car to mess up the cpu. Thanks and i appreciate the feed back
Old Mar 3, 2013 | 10:55 AM
NZXTInerTia's Avatar
Default Re: Performance chips
There really aren't any chips that will do you any good, at least nothing you will feel. At least not for our cars, you could try getting a chipped ECU with a stock basemap (I presume your car is stock).
Old Mar 3, 2013 | 01:26 PM
GhostAccord's Avatar
These plug and play chips that are being advertised are worthless.
Where you are running a V6... There aren't any OEM V6 ECU's that can be chipped and tuned. You will require an aftermarket engine management system/ ECU.
Old Mar 3, 2013 | 01:37 PM
redhatch 1964's Avatar
For any safe performance gains your car would have to be tuned. If your ecu can't be chipped it's best to stay stock.
Old Mar 3, 2013 | 01:58 PM
TheMuffinMan's Avatar
He knows where you live!
That's somewhat silly reasoning. I don't know of many OBDII Honda ECU's that can be tuned, there's no reason a '96 Accord should stay 'stock' because of it.
Downgrading to OBDI isn't too difficult and opens up the availability of using OBDI chipped and tunable ECU's
Old Mar 3, 2013 | 02:49 PM
Kevin2890's Avatar
Thanks for the input, knowing that i'll probably keep it stock
Old Mar 3, 2013 | 02:51 PM
Kevin2890's Avatar
Thanks
otacon122
Jul 26, 2007 02:59 PM
mnaines
Nov 4, 2006 06:42 PM
eppyhonda
Oct 8, 2005 11:01 AM
meekaswims
Aug 23, 2005 04:36 AM
smokin rubber
Dec 21, 2002 11:54 AM
