Electrical problem
I hit a curb in my 92 accord in january. I have been working on it since. Today I successfully got everything back together. I had the battery out the entire time. I charged the battery and stuck it back in and my car fired right up and I ran it for a while no problems. I shut it off and it started doing weird things. The blinkers started flashing and there was a clicking inside the car. The clicking continues even when the key is out of the ignition. Next time i started my car it died. I started it again and it started to die and i gave it some gas and it bogged out kept running for a second and bogged out again and died. I have no clue what is going on. Please help, if im missing some info let me know.
Are your grounds secure? There should be two general ground points on the front end of the car, that could perhaps cause your blinker malfunction. Maybe your alternator is bad, or the terminals aren't hooked up correctly or are dirty.
My alternator is more than likely bad. I already had to replace it once autozone sucks fat D. I have been trying to find the ground wires. I bought it from someone who ghetto rigged most everything on it. It also has MSD ignition could that be causing anything?
