ground wire for accord 92
the ground wire using for upgrade the car electric system and audio system something like that. This is the pic I found on the net <U>http://vstore.nopi.com/universalparts.asp?Level1=10&Level2=57&Level3=200& Level4=0&Level5=0</U>
just a ground wire is good but you also need to make sure you have a good ground. "upgraded wire is no good without a good ground. is this ground wire replacing another? grounds are very important. a bad ground will give you engine wine in audio.
