Window won't roll down
Old Mar 2, 2013 | 06:59 PM
ep3og's Avatar
Default Window won't roll down
Hello fellow HT members. My drivers side Window will not roll down anymore. The Window crank will move about 1 inch clockwise but the actual window will not move at all, not even a small amount. Does anyone have any pictures or suggestions on how to fix this?
Old Mar 5, 2013 | 10:46 AM
grog's Avatar
Default Re: Window won't roll down
The window may have come out of its tracks, or the mount or linkages could be broken.
Take off the inner door card to see what is going on.
Heres a write up on newer civics which should help you to understand the parts of the system, it looks very similar. http://www.clubcivic.com/board/showthread.php?t=103218
I had my door apart a while back and noticed that the rubber track for the window were loose and could slide up and down with the widow. I image if they came loose they could bunch up and cause a the window to bind.
But you'll have to open it up and see for yourself.
crxaddikt
17
Jan 13, 2015 04:04 AM
deerman2701
Nov 27, 2007 05:59 AM
i-want-a-crx
Oct 13, 2007 08:41 AM
Will_H
Apr 25, 2005 12:04 PM
io_burn
Oct 14, 2001 08:27 PM
