new mpfi problem
ok i have an 89 crx dx it has an a6 head and b8 block. using z6 mani port matched to gsr fuel rail tb and injectors. my problem is the iac valve on the z6 block there 2 nipples on the water jacket. one for iac and the other for the bypass. on my b8 block i dont have the iac nipple how do i hook it up?
When i did my mini me, i had to swap that coolant pipe out with the one from the Z6 so i could have that nipple for the IACV. It was a BITCH and a half since i didnt realize this until it was all together and in the car. Best bet would be to tale the intake manifold off and then try to switch it out.
Ek 2000
Jan 16, 2018 11:46 AM
doncapiku
May 18, 2016 10:29 AM
