Aftermarket Temperature Gauges - Defi / Aem - What type of temp element ? signal ?
Gday guys,
As i will be looking into doing calibration checks on automotive instruments in the future. I wanted to know some details on most the devices on the market.
Firstly on Temperature gauges. These usually comprise of a Element & a gauge with electronics.
For example
* probe reacts with temperature
* Probe transmits a signal to the gauge
* gauge interprets that signal and displays a reading.
Firstly what type of temperature element is used in most aftermarket oil & water temp instruments ? They usually always seem to be of a 2wire design but does not look like a thermocouple - so would it be a type of RTD or thermistor?
Secondly what type of signal is usually transmitted to the gauge from the probe? mv, ma, resistance change etc
Thanks everyone
Lyle
For example
Thanks everyone
Lyle
Gday guys,
For example
Thanks everyone
Lyle
For example
Thanks everyone
Lyle
I thought as much. Is the Upper and lower ranges of resistance usually the same? or is it range specific as well?
eg 0 - 100deg = 0 - 100ohm, 0 - 200deg = 0 - 100ohm
OR
eg 0 - 100deg = 0 - 100ohm, 0 - 200deg = 0 - 200ohm
Does that make any sense?
OR
JdM_HoNda
Jul 3, 2003 09:41 AM
