1999 accord 2door LX (ULEV) catalytic converter and exhaust
Old Mar 1, 2013 | 11:33 PM
Mike Bailey's Avatar
Default 1999 accord 2door LX (ULEV) catalytic converter and exhaust
Hello Honda-Tech forums. I am simply making this thread to document what had happened and what is the current state of progress on parts I have orderd to combat my cars previous failure with smog.
My vehicle is a 1999 Honda accord LX 2 door C.A.R.B certified Ultra low emission Vehicle (or ULEV for short)
I have had this issue for a long time now but finally have come up with the funds in attempt to combat the continuous on an off of my check engine light. The issue starts with the car failing smog check. The report reads a fault code and Carbon monoxide levels (CO) Being too high. Which is odd because 2 years ago the readings where different. This is usually in relation to the air fuel mixture which in turn is usually caused by reading from the O2 sensor in the catalytic converter that talks to the ECU. the 02 sensor in the front is good and pretty much new (OE nippon denso) so that is clearly not the issue.
Now here is the tricky part. The only part that is listed under that engine number for ULEV is ONLY sold by honda. The part number is
18160-PAA-L20
this is designated to the engine number found underneath the hood of my car (a small white square of a sticker that explains emissions)
XHNXR0130AAA
HOWEVER. There is another converter made by magnaflow that is very likely to be almost identical in terms of it's workings (yes it is California Approved)
it is the magnaflow 46615
Link is here
http://www.amazon.com/gp/product/B0025QG6KK/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1 http://www.amazon.com/gp/product/B0025QG6KK/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
I have already placed an order of this on Amazon and there is a comment written by a user who has the same exact ULEV vehicle. They said the light did not go off after that. Then not only that, they gave an update 2 years later and said that it is still working with no issues at all.
Another thing that I must note is that the current catalytic converter I have on, to my own shock (because I originally expected it to be the one that was installed out of the factory) is missing a heat shield that I never noticed was even supposed to be on there in the first place AND is welded straight to the resonator (pipe that leads to the muffler, Work was most likely done by a muffler shop from the original owner). I ordered 2 brand new heat shield parts (2 total in plastic honda genuine parts packaging) off of ebay for about 34 bucks. which is good because it's 32 each at the dealer
and a new resonator linked here as well
http://www.amazon.com/gp/product/B000C8ZFL4/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1 http://www.amazon.com/gp/product/B000C8ZFL4/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
This resonator is fitted towards the coupe model. The sedan numbering is different.
While I was at it I also ordered new rubber mounts (made by bosal)
and a new Denso 02 sensor as well as a new gasket for the rear part of the resonator that connects to the muffler. The only thing I have left to hit is finding the right bolts. The only odd one seems to be the ones for the heat cover. It is an Itawa 6x10 bolt according to the diagram from the dealer. The other bolts I do believe I can get from any hardware store (forged bolts preferably)
One last thing to note is that I ordered a bluetooth mini BODII scanner off of Newegg and bought the torque pro metering app for my android phone. I am very excited to see all of the systems working real time on my phone.
If anyone knows what the sizes are for the exhaust bolts that join the flanges please let me know ,Mike
Last edited by Mike Bailey; Mar 1, 2013 at 11:54 PM. Reason: correcting a few mistakes and adding a couple of words
Monotremata
Aug 5, 2020 05:36 AM
chitos
Mar 28, 2013 10:26 AM
Mike Bailey
Mar 12, 2013 08:49 AM
stackcheese
Sep 22, 2008 04:21 PM
terryowens
May 25, 2006 12:46 PM
