paxton fuel pump with stock lines? help
Old Oct 21, 2002 | 05:09 PM
paulzy's Avatar
Default paxton fuel pump with stock lines? help
I was thinking, can I just splice my paxton into the hard steel line feeding the engine? kinda liek the smaller pumps that come with the kits?
kinda like this:
tank--->hard line--->paxton pump--->paxton filter--->rail--->braided return line
if I can do this, what size line should I run for the return line? Or should I be fine with the stock return lines as well?
Old Oct 22, 2002 | 06:38 AM
downpipe's Avatar
Default Re: paxton fuel pump with stock lines? help (paul_vang)
it may stress the pump too much...i know that aeromotive suggests using -10an feed, and mounting in a place which allows gravity to assist fuel delivery...
as far as feed and returns lines go, i'm no expert but i knwo that send is typically bigger than return...
Old Oct 22, 2002 | 02:07 PM
paulzy's Avatar
ttt
Old Oct 22, 2002 | 03:35 PM
turbologist's Avatar
Default Re: paxton fuel pump with stock lines? help (downpipe)
Thats true, it does have to be a gravity feed assisted or the pump will burn itself out. As far as using your hard lines, they can only handle so much power and if you feel as if you need a inline high output pump then maybe you shouldnt skimp on the lines. I think stock honda lines can handle ~400 whp. Dont quote me on that. I suggest that you get the appropriated plumbing with the delivery system in order to be effective. HTH
B_Swapped93
May 15, 2017 03:33 PM
danedoremus
Welding / Fabrication
21
Nov 7, 2011 11:58 AM
disordinate
Mar 27, 2009 02:57 PM
dmotoguy
Mar 2, 2008 10:27 AM
civickiller
Apr 9, 2004 04:18 AM
