Suspension & Brakes Theory, alignment, spring rates....
94 Honda Civic ABS light...
Old Mar 1, 2013 | 07:21 PM
Blaze45's Avatar
Brrraaaap!
Default 94 Honda Civic ABS light...
The light is on in a car that I just picked up. Connected the service connector and the SRS (not the ABS light?) just blinks a million times an hour. Apparently I am doing this wrong? The blinking isn't anything like when I pull a DTC from the CEL.
Any help would be great so I could get an idea of what is going on....
Thanks!
Old Mar 1, 2013 | 07:53 PM
go-part's Avatar
Default Re: 94 Honda Civic ABS light...
http://forums.clubrsx.com/showthread.php?t=308198
Try resetting the light and see if that helps.
Old Mar 1, 2013 | 09:45 PM
Blaze45's Avatar
Brrraaaap!
I already did... I also tried to reset the ABS light by removing the fuse and disconnecting the battery. Still on.
Old Mar 2, 2013 | 02:46 PM
Blaze45's Avatar
Brrraaaap!
Also tried to re set the code by using the brake pedal with the service connector in. Didn't work.
AngelRay
Honda Civic (2006 - 2015)
Jul 28, 2017 10:51 PM
Blaze45
Mar 12, 2013 02:59 PM
Purple94EX
31
Jul 13, 2006 04:43 AM
Fliplm0de
May 9, 2006 08:08 PM
cdoucet
Jan 28, 2006 04:08 PM
