Moog Rear Trailing Arm Bushings
Nope. Just pulled the trailing arms off enough to bang it out with a hammer. Took some choice words and a lot of good hits but I got them in.
A hammer is a lot cheaper than a 180 dollar tool you'll probably only use once. Just make sure you get it all lined up right and it shouldn't be any problem.
Also I have no idea why people suggest burning the old bushings or cutting them. They come out a million times easier than they go in, it took me maybe 4 even hits on each side and they popped right out.
Mine came out with around half a dozen hits each. Since I had the arms off (only takes 5 bolts) I used my $99 12 ton press from harbor freight.
My son ran the pump handle while I moved the arm around. maybe 10 minutes an arm.
I used the dormans from Rock auto.
Jon Petersen
Dec 19, 2018 06:12 AM
