obd2 iacv problem?!!
Old Feb 28, 2013 | 10:11 PM
whoiszdizguy's Avatar
Icon2 obd2 iacv problem?!!
[B]whats going on honda tech, ive tryd almost everything n cant get my iacv code 14 away ..heres the lay down
•obd2 2001 ls block
•95 gsr head
•2000 honda civic ex coupe/stock wire harness
ok so heres the deal. i put an lsv turbo in my 2000 ex if i have the stock p2t single ecu it doesnt have any codes... but car runs like **** being that its not a single cam motor.
so i got a stock p28 with step down. plugd it up. n im getn code 14.
when i give it gas it stutters/bogs at 2rpms like a ghetto 2step. if i floor it hard its ok.
so i tryd cleaning iacv still gets code.. swapd it twice with to friends cars that was runin good. still gets code.
ive tryd several p28 ecus chipd n stock also p75 . and still bogs at 2rpm. only time it doesnt is with the stock oem ecu to the car..
i lookd up the obd2 to obd1 iac ecu pin out n my ecu plug its already how they say i should repin it.
idk what it could be. hopefully someone had this problem and was an easy fix. thnks HT
all feed back wanted
Old Mar 1, 2013 | 06:56 AM
1998GsRIntegra's Avatar
Default Re: obd2 iacv problem?!!
Did you try bolting up an obd2 iacv?
Old Mar 18, 2013 | 01:27 AM
yes i put and obd2 iacv and now om currently runing an obd1 iacv n problem still occurs
Old Mar 23, 2013 | 12:19 PM
bumpp anyone??
juba_x
14
Jul 14, 2014 02:54 PM
tatayee
Jan 26, 2014 07:19 PM
b20izzle
Oct 26, 2005 07:53 PM
AzNpRiD3
May 14, 2004 06:05 PM
