Starter Solenoid
Old Feb 28, 2013 | 09:17 PM
Dekorum's Avatar
Default Starter Solenoid
I have a 92 hatch with a B18C, so I was wondering if the starter solenoid for this motor is the same as any Civic starter solenoid? Also, how come Honda does not sell just the solenoid? I only see the whole motor on Majestic Honda and it's a ton of money!
Old Mar 1, 2013 | 05:00 AM
Former User's Avatar
Default Re: Starter Solenoid
First off, what makes you think that your starter solenoid is bad?
Old Mar 1, 2013 | 06:19 AM
Dekorum's Avatar
Intermittently, usually during road trips where my bay gets rather hot, I will get back in the car after stopping for gas and turning the key will do nothing. The power for everything goes on but there is not a sound in terms of clicking where the motor is trying to turn over. This has got to be either the ignition switch or the starter solenoid taking a crap. Usually the ignition switch is never an intermittent problem, right?
Old Mar 1, 2013 | 06:50 AM
bisscrac's Avatar
i had this exact problem. i was pulling my hair out changing things left and right...... it ended up being that the starters from advanced are ****** garbage (2 of them). Een though they would test it and say it was good over and over again.... i ended up getting a used HONDA one off craigslist and since that day i have never had the problem again. that was 2 years ago.
might not be your problem but i just figured i would share my story it sounds like my exact problem i was having....
Old Mar 1, 2013 | 06:54 AM
Dekorum's Avatar
Great advice. I do not think I have an advance auto starter though, it is the one that came on the swap when I got it from Steve at HMO. I guess it's some japanese brand, probably just Honda. Thanks for the story, now I am still wondering if I should do the same.. I am going to look on craigslist, but now I ask the question again: which starters can I use? For example can I use one from a D series Civic, or only a B series, if so which ones?
Old Mar 3, 2013 | 08:04 AM
bisscrac's Avatar
b-series 5 speed starter.
Old Mar 3, 2013 | 04:04 PM
Dekorum's Avatar
Ok, so that includes LS motor also?
I hope that this problem happens again soon, so I can test a few things out before I buy anything. The clutch interlock switch is the first thing I am going to test for, this might be that switch that is going bad.
Old Mar 3, 2013 | 04:11 PM
vitamin_c95's Avatar
I replaced my starter think it was a bad solenoid. Still had the same issue. Ended up being my switch. Just FYI. It is pretty common. Troubleshoot it right
Old Mar 3, 2013 | 04:48 PM
Dekorum's Avatar
Your clutch interlock switch? I wish I could figure out the problem now, but since the problem is intermittent I have to wait until it happens again. Did you just jump the 2P clutch switch connector and see if it started up when it was not working?
Old Mar 4, 2013 | 04:01 AM
axis11's Avatar
Do a bench test on the solenoid and starter. Or test it while it is in the car.
Old Mar 4, 2013 | 05:20 AM
94EG8's Avatar
Seagull Management
Yes.
PhilUp24
Aug 16, 2013 06:15 PM
33steviebix
Oct 26, 2011 04:44 AM
granadablanca
Sep 27, 2011 05:34 AM
EG6-SIRII
Jan 12, 2007 01:50 PM
bboy21385
Dec 2, 2004 10:45 PM
