Help... B16 running on 2 cylinders
Ok guys here's why's going on, have a 90 crx dx. Did a dpfi to mpfi. My car is only runnin on cylinders 2 and 3. Can pull plug wires from 1 an 4 while running with no change in engine idle at all. Could it be a crossed/ backwards wire from the conversion? Oh and if it matters I'm running obd1, p30 ecu. Haven't wired vtec or 02 sensors up yet. Any input will help guys. Thanks in advance.
Update: I'm getting great spark on both of the cylinders, so I'm assuming no fuel. Pulled the fuel rail and turned the key but no fuel from any of the injectors? Am I missin something or should I have got fuel on he keyturn
Did you wire in the injectors? MPFI swaps require some wiring changes. A "crossed or backwards" wire will definately lead to issues like this.
Check here: http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Also do you have the correct injector and resistor setup? you need the right combo (sorry I forget whats needed)
A safer way of checking the injectors is to unplug them (like you did with the spark plugs) one by one listening for changes in the engine. You can aslo listen for the "click" of the injector with a long tube/hose to listen with (one end in your ear the other to listen with)
Fuel should only spay when the motor is cranking over, It will only come out of the fuel filter the way you tried ( with the banjo bolt loose).
