00 Em1 requires starting fluid to start but runs fine after.
So I've searched quite a few forums but cannot find my situation. Here's the Scoop
00em1 all stock.
Car ran perfectly fine getting ready to start a huge Turbo build on it.
Relocated battery to the trunk. Ran a 2gauge wire from battery to.under dash. Used a splitter to run 1 wire to fuse box and another to the starter.
Car is getting fuel to the rail.
Its getting spark.
But will only start with starting fluid
When it starts with starter fluid it runs fine I drive it around the block like it never had an issue. I come home turn it off And it will not start back up. Once again I spray the fluid starts fine runs fine.
Any ideas would be greatly appreciated. Thank you
00em1 all stock.
Its getting spark.
Fuel filter is new. Actually all the lines leading to the rail have been replaced with-8 lines with an earls inline. And yes I do give it some throttle while trying to start.
Accord15
Jun 25, 2003 09:54 AM
