Is Rywire still in business?
Old Feb 26, 2013 | 03:27 PM
RuneRavenX's Avatar
Icon2 Is Rywire still in business?
I went to Rywire's website and noticed that their copyright is from 2005 to 2011. I also called their customer service number and was told it was no longer in service. Anyone have any info on them? Was looking for a conversion harness for a d16z6 swap because I don't want to splice wires myself.
Old Feb 26, 2013 | 03:38 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Is Rywire still in business?
http://www.rywire.com/catalog/index.php
1-240-479-9473
No idea what you are doing wrong.
Old Feb 26, 2013 | 03:43 PM
RuneRavenX's Avatar
1-240-479-9473
Hmmm, looks like I was having cell issues I guess. Redialed it a bunch of times and it finally went though. Their closed anyway, but at least I know it works.
Now for another question: for a d16z6 conversion with a conversion harness, do I need a z6 factory harness also? Instructions for the conversion I have seen don't explain the Rywire harness so I'm not sure what all I would need for the swap in terms of wiring.
Old Feb 26, 2013 | 03:48 PM
dc5itracer's Avatar
If its going into a mpfi civic no if its going into a dpfi civic you can use exsisting harness just need modify it to mpfi and obd1 real simple
Old Feb 26, 2013 | 03:53 PM
4drEF's Avatar
Keyboard Humorist
RyWire is a reliable source for the conversion harness which allows you to use an OBD1 ECU.
You convert your stock engine harness to fit the Z6 engine.
Old Feb 26, 2013 | 06:02 PM
RuneRavenX's Avatar
What needs to be converted using the stock harness? I know there are write-ups but I just don't know where to start if I use the Rywire harness.
Old Feb 26, 2013 | 07:15 PM
dommyy13's Avatar
do you have an si? or another model
Old Feb 27, 2013 | 06:13 AM
RuneRavenX's Avatar
Si. All stock a6 motor with L3 tranny.
Posted from Honda-tech.com App for Android
Old Feb 27, 2013 | 07:02 AM
4drEF's Avatar
Keyboard Humorist
The O2 sensor will be 4 wires, distributor plugs will be different, alternator plug might be different, and the fan switch connector will need to be switched out and relocated from the back of the motor to the thermostat housing.
If you use your stock A6 fuel injectors then you don't need to do any modification there.
It think that's it for the plugs you need outside of what the jumper/conversion harness should provide.
Old Feb 27, 2013 | 06:24 PM
91legend's Avatar
Lucky for you, I literally just did this swap. You use your old harness and beware, there WILL BE a couple of plugs that you WILL NOT use on the old harness. USE YOUR OLD HARNESS AND INJECTORS. The rywire harness WILL HAVE the wires already pinned to a connector for the 4 wire o2 sensor. It literally a plug and play harness.
Also, I couldn't use the z6 axles on my Hf but it could be different for you since you have the Si.
Old Feb 27, 2013 | 07:33 PM
RuneRavenX's Avatar
I was thinking that I reuse my axles from my Si tranny. Could be wrong though.
trip-doh
Jan 19, 2009 03:08 PM
JDM_EK_JOE
May 1, 2006 05:44 PM
kanzenr91si
Mar 12, 2003 03:20 PM
