92 civic power doors harness diagram needed...
Old Feb 26, 2013 | 10:52 AM
kali.crooks.eg6's Avatar
Icon2 92 civic power doors harness diagram needed...
ive been looking everywhere for a 92 civic power door harness diagram.not the one inside the door but the plug to the doors....
Old Feb 26, 2013 | 01:21 PM
angrysmileyface's Avatar
Default Re: 92 civic power doors harness diagram needed...
If you find one, good luck, I havent found a door pinout for the interconnect to save my soul. Basically you just have to see what colors are on both sides. (I know there is one out there for the 96-00, RonJ has posted it many times before)
Old Feb 26, 2013 | 01:31 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
So, you need to know which wire colours go where on the 25-pin connector at the door? Is this what you're both looking for?
Old Feb 26, 2013 | 01:33 PM
yup exactly...i saw the diagram for the 96-00 but the wires arent the same color so i wasnt able to use it..
Old Feb 26, 2013 | 01:34 PM
dammm...ive been looking for it for weeks man i thought it was just me..
Old Feb 26, 2013 | 01:59 PM
deschlong's Avatar
Loved
Community Favorite
I believe I have this info, but I'll need a day or two to sort out what I have ... it's in a couple of different places.
Old Feb 26, 2013 | 02:12 PM
dammm if you can get a hold of it that would be awesome....
Old Feb 27, 2013 | 09:02 PM
deschlong's Avatar
Loved
Community Favorite
OK, here's what I've got. Attached is a PDF with a table full of information. Included is info for the 92-95 CDM / USDM Honda Civics as well as for an RHD JDM EG6. Source for this is the CDM / USDM Electrical Troubleshooting Manual (ETM), the JDM ETM, the OEM JDM Honda Access Installation Instructions for Power Heated Mirrors, and my own experience / research.
Last edited by deschlong; Feb 9, 2015 at 05:48 PM. Reason: EDIT: FINALLY updated the image of the pinout of the door connector.
Old Feb 27, 2013 | 09:51 PM
OK, here's what I've got. Attached is a PDF with a table full of information. Included is info for the 92-95 CDM / USDM Honda Civics as well as for an RHD JDM EG6. Source for this is the CDM / USDM Electrical Troubleshooting Manual (ETM), the JDM ETM, the OEM JDM Honda Access Installation Instructions for Power Heated Mirrors, and my own experience / research. The image of the 25-pin connector is temporary - I have a better one that more accurately displays the actual pin layout / design which I will upload at a later date.
dammmm..i was going to make my own harness for power door conversion but honestly am just going to get the harness at the junk yard and save myself a huge headache...but thank you i had been looking for that for a while and it was nowhere to be found!!!
Old Feb 27, 2013 | 10:00 PM
deschlong's Avatar
Loved
Community Favorite
Yes, I strongly recommend you get an original harness and just use that. Much easier.
Old Feb 27, 2013 | 10:06 PM
believe me thats what ill do...do you belive its possible to remove the harnes without removing the dash?
Old Feb 27, 2013 | 10:10 PM
deschlong's Avatar
Loved
Community Favorite
I've done it, but it will take you longer than just removing the dash! (Which is actually pretty easy.)
Old Feb 28, 2013 | 03:44 PM
Deschlong is my hero! Now I at least know what pins are where....
Old Feb 28, 2013 | 11:06 PM
ill hit the junk yard this weekend and get the harness....and yeah removing the dash is pretty easy....it was definetly worth it for my wire tuck!
Old Mar 1, 2013 | 05:22 PM
deschlong's Avatar
Loved
Community Favorite
Happy to help ... what are your plans?
Old Mar 2, 2013 | 04:58 AM
Im still in the process of setting up the heated mirrors and rewiring the doors after adding the keyless entry from the CR-V (Im using one of the blank spots to pass back the domelight signal wire)
Old Mar 2, 2013 | 07:01 PM
tlarimer's Avatar
Deschlong beat me to it, I am pretty sure I have this too from when I built my dash subharness for power door conversion...
Old Oct 17, 2013 | 01:05 PM
lilzed747's Avatar
hey deschlong. awesome post. was wondering if you had the more accurate pin layout diagram yet? i am trying to pre-wire my car for pfhm and trying to integrate everything with my current USDM PL PW PM setup. that updated diagram would work wonders. thanks in advance
Old Oct 17, 2013 | 01:22 PM
deschlong's Avatar
Loved
Community Favorite
^ Well, the numbering is accurate, but it just doesn't reflect the physical pin layout on the connector in the best way possible. Feel free to use it as is, but I do have something that's better ... somewhere.
Old Oct 17, 2013 | 05:27 PM
lilzed747's Avatar
im a bit of a noob when it comes to wiring.ill give it a shot with this one but if you find the other one that would be sweet. i still have to find a place to buy the right colored wires anyways so no rush
Old Oct 17, 2013 | 05:38 PM
deschlong's Avatar
Loved
Community Favorite
I'll tell you right now, there's nobody that can supply the right colour of wires. I don't know why. Well, I looked around back in 2008 and it was basically impossible. I wound up just pillaging wire from existing junked cars. It's a lot of work but that stuff is basically free when you go to pay for it, and it has been remarkably useful over the years.
Old Oct 17, 2013 | 05:42 PM
lilzed747's Avatar
damn. not even from honda? (i guess that would be expensive tho..) thats a good idea for the junk yard. thankfully the harness for the accessories isnt very long so it should be easier.
Old Oct 17, 2013 | 05:55 PM
deschlong's Avatar
Loved
Community Favorite
Rest assured that if this is your first time, then nothing will be 'easy'. It will require much perseverance and learning on your part to get it done properly - which is what I trust you are aspiring for. That "extra" wiring from a pulled harness will come in so much more useful than you will ever know - especially if you're determined to match wiring colours.
By the end you will http://en.wikipedia.org/wiki/Grok wiring.
Old Oct 18, 2013 | 04:48 AM
Extra wiring pulled from busted cars works out to be wonderful. I have a couple boxes of the stuff just as suggested from the Master of OEM luxeries. It has made installing heated seats, compass mirror, heated outer mirrors, retrofitting the lock system to be a lot easier. I expect when the time comes for the engine swap, that having the extra wiring will make a lot of that easier as well.
Old Oct 18, 2013 | 06:58 AM
lilzed747's Avatar
You guys have any recommendations for which cars to target? I'm assuming for the most part Honda prolly uses similar colored wires across the board? (I hope my qs aren't thread jacking.lol)
Deschlong: nice use of the word grok.definitely gonna use that on an assignment to stump a prof.lol
