... to sleeve or not to sleeve... that is the question
Old Oct 21, 2002 | 03:24 PM
1.8T_EG's Avatar
Default ... to sleeve or not to sleeve... that is the question
current setup : see sig
goals :
- 22-23psi
- 350-400whp
can i get there with just pistons/rods and tuning?... also, what are everyone's recommendations for achieving my goals?... lemme know... thanks in advance...
Old Oct 21, 2002 | 03:28 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: ... to sleeve or not to sleeve... that is the question (1.8T_EG)
sleeve.
Old Oct 21, 2002 | 04:05 PM
tygsr's Avatar
Default Re: ... to sleeve or not to sleeve... that is the question (vtecvoodoo)
To search or not to search that is the question.. Plenty of info on it..
Old Oct 21, 2002 | 04:33 PM
SlowB16's Avatar
Default Re: ... to sleeve or not to sleeve... that is the question (tygsr)
Or people could help him out without saying search first. You probably want to sleeve, but dont neccesarily have to. A guy on here made 508 hp with stock sleeves, but that is perfectly tuned with the Motec. I think that it would be safer to sleeve your motor, but you MIGHT not have to.
Old Oct 21, 2002 | 08:11 PM
1.8T_EG's Avatar
... thanks for the info ... next time dont both replying... i already did a search... now did you not answer because you didnt know... or because you were too lazy to help... i doubt you were too lazy cuz you wasted you time so say "search"... so i am gonna have to go with the fact that........ whatever....
slowb16 : thanks for the reply...
Old Oct 21, 2002 | 08:21 PM
SiRkid's Avatar
up to you...got the money, do it!
it will give you peice of mind and youll know you wont crack a sleeve
BUT the stock sleeves CAN handle your power goals no problem. (good tuning)
Its up to you really.
fyi, someone made like 608 WHP on stock sleeves
[Modified by SiRkid, 5:22 AM 10/22/2002]
Old Oct 23, 2002 | 06:34 AM
1.8T_EG's Avatar
Default Re: ... to sleeve or not to sleeve... that is the question (SiRkid)
... at what point would you re-sleeve your car?... 12 psi?... 15 psi?... 18 psi?...
Old Oct 23, 2002 | 06:40 AM
DSF's Avatar
DSF
It's not a pressure dependant thing. The general concensus is typically 350whp is "safe" on stock sleeves. More is <U>possible</U> with a higher degree of tuning. Sleeves are usually damaged by detonation, not horsepower alone.
Old Oct 23, 2002 | 06:51 AM
DIRep972's Avatar
Smarter than you
once u sleeve a block, it can be your block forever. keep that in mind when looking at the price for a new core if u happen to crack a sleeve.
can it be done on stock sleeves? yes, it obviously been proven. but should u run it on stock sleeves? yes or no depends if u want to take chances.
&lt;will be sleeving when he builds
Old Oct 23, 2002 | 07:30 AM
ekb18c's Avatar
sleeve!!
Old Oct 23, 2002 | 07:34 AM
DSF's Avatar
DSF
Default Re: ... to sleeve or not to sleeve... that is the question (DIRep972)
Yep, same here Actually, my GE block is already sitting in my living room My hp goals were right on the edge of reliability giving the tuning available to me, so I erred on the side of caution.
Old Oct 23, 2002 | 08:28 AM
1.8T_EG's Avatar
OFF TOPIC
DIRep972 : what setup are you running right now?... i saw your sig and was curious... thanks... nice numbers btw...
killer_siller
Mar 8, 2009 10:12 AM
integraboosted
Nov 13, 2005 06:11 PM
EGgwhite
May 4, 2005 09:21 PM
KMK1605
Nov 4, 2003 06:07 AM
Big Phat R
Jun 28, 2001 02:11 PM
