How do the weep holes on a water pump work?
Old Feb 26, 2013 | 04:13 AM
einzelherz's Avatar
Default How do the weep holes on a water pump work?
My g/f's 98 LX four door with 100k miles started losing water in the past couple of months and preliminary inspection shows it coming out of the water pump since it's only dripping from the lower front cover, but I haven't had them off to verify yet. The water pump was changed with the timing belt almost exactly 10k miles ago. It's not a Honda pump, IIRC it's a Bosch.
Could it really be bad already? Is it possible that something else is the problem like I messed up the seal?
Thanks in advance.
Old Feb 26, 2013 | 05:28 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: How do the weep holes on a water pump work?
I had an aftermarket one go out a month after I replaced it. Mine had a crack in the housing. OEM all the way.
Old Feb 26, 2013 | 07:00 AM
94EG8's Avatar
Seagull Management
Absolutely. It may have been defective right from the get-go. It happens. Those aftermarket waterpumps are junk though. I have yet to see an OEM Honda pump within the timing belt replacement interval.
Possible, but it's more likely it's just a bad pump. If there's coolant on the timing belt I'd replace that again too.
Old Feb 26, 2013 | 11:55 AM
angrysmileyface's Avatar
Just replace the pump with an OEM one. I replaced the OEM one on my 93 at 90k with a GmBH and 60k later the pump began weeping. Decided after I was tired of refilling the radiator every 3 or 4 days and getting a water stain on my driveway I would just do the belt and pump again. Did it with OEM and no problems.
Old Feb 26, 2013 | 12:04 PM
Emeraldbomber's Avatar
Pretty much oem everything in my book. Aftermarket just doesn't have the same quality
Old Feb 26, 2013 | 12:36 PM
zacheryleatherw's Avatar
I got a a1 coradone one from oreilly there just rebuilt oem waterpumps I didn't have a problem with mine up till it got stolen. I think it was only like 30 buck's I believe...but I used to work there so I'm sure I got a discount on it. But even without a discount I don't think there much at all. If they do go out you get another one for free cause they have a lifetime warranty.
The-Kid
May 12, 2011 08:09 PM
RACEPAK
Aug 20, 2005 02:46 PM
turq93t
10
May 16, 2005 06:00 PM
92SiBlu
Apr 18, 2004 03:09 PM
Volcom
Jan 23, 2002 10:31 AM
