power assembly relay amp?
From this I read just 50 milliamps but I think it was sayin as a draw tho
http://www.bcae1.com/relays.htm
Thats the starter relay, right?
I'm curious why you need to know this rating?
Are you trying to replace it with something other than stock?
I checked a spare relay and it has no amperage rating on it. The starter signal circuit is 10 amps (not sure that helps)
EF cowboy, Number 4 is the atmospheric pressure sensor or PA sensor. "It converts atmospheric pressure into electrical signals and inputs the ECU"
thanks for your responses guys
but yea grog, the shop i took it to snipped off the old relay and replaced it with a 30 amp bosch one and im just making sure it is the right one
As long as it works (obvious) and handles more amperage than the fuse go to it, then you are fine.
