PA 93 Civic LX sedan Auto
Fellow Honda loyalists, I have up for sale my trusty 93 Civic LX. It has faithfully served me well in times of need, and continues to do so, but it is time to move on. Asking $1500 obo.
Located in Media, PA.
Call or PM: 215-565-5014
Known issues and services performed:
117k on the odo. Purchased 2nd hand @ 100k.
Oil leak from front main seal. Leaks about half a quart every fill up. May leak some from rear main seal.
Driver side rear window no longer works (stuck in the up position).
Cracked windshield. Happened in October but hasn't gotten worse so I didn't have it replaced.
Paint is tired and previous owner tried to rattle can it (most of which I pressure washed off), but body is rust free.
Interior has many cigarette burns from previous owner as well.
I just bled the brakes and had the rotors turned so it stops smoothly and with conviction.
Oil changes @ 3k with 5w30.
In the summer I checked oil pressure. Oil pressure reads 72 psi @ 3k.
Recently flushed and replaced steering fluid.
Inspection in August revealed a exhaust leak in the mid-pipe. Had mechanic replace. Passed inspection. Good until August.
Replaced Faulty dimmer switch. Gauges go dim from time to time still due to a issue w/the connector or wire near connector.
Air conditioner needs to be re-charged. Refrigerant leaked out slowly over the course of 2 years.
Purchased May 2010 and did the following:
Rotors & Pads, replaced muffler section of exhaust, Oil, spark plugs & wires, distributor cap, air filter, PCV valve, steering & AC Belts, idler pulley, valve cover gasket, replaced rear seat cushion & seat belts, replaced front right axle, faulty vehicle speed sensor. Several months later I replaced the oil pan gasket.
Thanks for looking!
Pictures:
Thanks for looking!
Pictures:
Obviously not a ton of <3 on here looking at the other vehicles available for sale. But just bumping, probably for the last time. Have a couple interested sellers. If you are at all interested, call me as soon as possible. Thanks.
mickeywickit
Sep 26, 2004 09:08 PM
