Is it possible for Vtec solenoid to be bad?
Old Feb 25, 2013 | 07:04 PM
1991ED6's Avatar
Default Is it possible for Vtec solenoid to be bad?
I am doing a z6 head swap...the head i was going to use had to get machined out,it was warped way beyond spec.
I plan on using the solenoid that came off of the bad head, is it possible for it to be bad.
I did clean it out with carb cleaner. thanks
Old Feb 25, 2013 | 07:10 PM
desert_brownie's Avatar
Default Re: Is it possible for Vtec solenoid to be bad?
Solenoids can go bad. The manual has a test to check if its working right. I cant remember off the top of my head whether its the resistance or the voltage across it that has to be measured.
Old Feb 25, 2013 | 07:15 PM
1991ED6's Avatar
Ok great thanks for info, ill check up on that
89ED
Sep 14, 2013 01:26 PM
90DAkid
Jan 10, 2007 08:54 PM
the DA in HONDA
Aug 20, 2004 10:45 AM
civickiller
Aug 10, 2004 05:04 AM
chron1k
Aug 19, 2003 05:23 PM
