fuel pressure regulator
Old Oct 21, 2002 | 02:57 PM
non vtec's Avatar
Default fuel pressure regulator
my car has minimal engine mods - intake and exhaust. i once read that increased fuel pressure is a good idea to compensate for the increased airflow. my car is running fine, obviously i don't NEED it, but am i lacking power by not having a fuel pressure regulator?
Old Oct 21, 2002 | 03:04 PM
94gsr's Avatar
Default Re: fuel pressure regulator (non vtec)
No - not with just an intake & exhaust.
Old Oct 21, 2002 | 03:06 PM
98DC2's Avatar
Default Re: fuel pressure regulator (94gsr)
...so after how many minor mods (I,H,E,ITM,etc...) would you recomend using one?
Old Oct 21, 2002 | 04:07 PM
94gsr's Avatar
Default Re: fuel pressure regulator (98DC2)
Best way to know when you need one would be to acquire something that allows you to monitor your A/F mixture. But as a generaly rule, you'll need to substantially increase the flow capabilities of your engine before this is a necessity. This flow increase could be in the form of cams, a good port job, or a very good intake, TB, IM, header & exhaust combo, or any combination of the three. It's really application-specific though. In my case, I had a 2.5" header collector & 2.5" piping all the way back with no cat, a 3" custom intake, & a CTR intake cam. The only reason that I needed an FPR even at this point, was because I had removed my IAB valve body which causes me to lean-out from 4400-5750. With the IAB valve body in, I was still running rich all the way through my rpm range.
Old Oct 21, 2002 | 04:26 PM
Tweakmeister's Avatar
dyno
meheartmycivic
Jul 5, 2010 05:00 PM
jaref9
Jun 27, 2009 11:35 AM
2kdrift
Oct 8, 2007 03:48 PM
91civichatch2571
Jan 6, 2005 09:15 AM
