Custom 3" exhaust over LCA Pictures
Old Feb 24, 2013 | 07:39 AM
ZCHondaCRX91's Avatar
Default Custom 3" exhaust over LCA Pictures
So I'm making a custom 3" for my CRX. The only part I'm not sure of is at the LCA. There is very little space so I have to think about where I want it to route. I'm trying to tuck the exhaust up toward the body as far as I can and it seems like I can get the exhaust straight through the LCA opening or maybe with a slight "hump." With 2-2.5" exhausts I could do a hump and still have it tucked closely to the body, but with the 3" it looks like I need some tight angles. The muffler will be coming out the passenger side so right after the LCA the muffler starts.
If any of you guys have 3" exhausts on your CRX can you post up how you have the exhaust at the LCA? Thanks.
Old Feb 25, 2013 | 06:43 AM
Default Re: Custom 3" exhaust over LCA Pictures
I'd really appreciate it if any of you guys can snap a quick picture of your 3" over the control arm.
Old Feb 25, 2013 | 07:42 AM
h2.4's Avatar
this is an ek but I tucked in inboard so the control arm would have less chance of rubbing it.
Old Feb 25, 2013 | 08:18 AM
TPB's Avatar
TPB
^^^ same on my eg
Old Feb 25, 2013 | 02:00 PM
Did you have a problem with it hanging too low or the top of the hump hitting the frame? Did you use one U-bend or something else to get the shape? Thanks for the response.
Old Feb 25, 2013 | 05:20 PM
h2.4's Avatar
no, if you spend enough time getting the fitment right it will tuck and not rattle or rub. Thing is it takes some time to get good fitment. I used all 90* bends and cut and sanded to get the proper angles. All of the fitment is gapless, so it takes some time to sand the fittings on the bench sander to get it perfect. It looks like just two 45's and a 90, but not one of those mandrels is left unsanded. Every single one is sanded to fit the next. I have this one set up with about 1/2" space at the top of the hump and 1/2" tucked up into the body of the car elsewhere. No rubbing or rattling at all. And it doesn't scrape on the ground either. Just gotta take the time on the fitment.
Old Feb 26, 2013 | 07:13 AM
Do you think I would be better off with (2) 45* bends and (1) 90* bend to get that, or just get a couple U-bends and just cut/angle until it's a smooth hump?
On my CRX it looks like I have about 5-6" above the control arm so it will be kind of tight. My rear coilovers are 12kg/mm spring rates so the control arm shouldn't move up and down very much.
89efhatchy
Jul 22, 2013 07:54 AM
94eh2
11
May 5, 2009 07:24 PM
Dancing is Forbidden
12
Nov 29, 2005 03:03 PM
tvrcrx
Mar 30, 2004 06:49 PM
PA MATT
11
Mar 23, 2004 07:55 AM
