Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
hard to shift on high rpm?
Old Feb 24, 2013 | 07:31 AM
EK FLY's Avatar
Default hard to shift on high rpm?
08 fa5 with 92k on the clock , at 72k i did the trans oil with honda manual transmission fluid car has been female driven its entire time with occasional vtec to redline engagement by me
now iam starting to experience hard shifting when iam going from first to second then 3rd shifting in between 5k to 7k it will allow me to shift only when the rpms go below 5k with will engage in gear ,
any clues on what could happens ? maybe difference oil weight i remember when we put gm syncro mesh on b series no get rid of some sord of grinding
Old Feb 24, 2013 | 07:40 AM
EK FLY's Avatar
Default Re: hard to shift on high rpm?
this guy can descrives whats going on with my tranny
http://www.8thcivic.com/forums/mecha...-solution.html
Old Mar 5, 2013 | 12:30 AM
Deksinjo's Avatar
and this guy can help you if you have not destroy gear box
http://www.8thcivic.com/forums/trans...-shifting.html
Old Mar 6, 2013 | 11:21 AM
HRsi-dan's Avatar
You're just adjusting the clutch pedal which will help but can only do so much.
Another known fix is to replace the clutch master cylinder completely with one off of an older Civic. Look up the EM1 cmc replacement on 8thcivic. Our CMC is known to be garbage and is internally made up of crappy plastic components.
arielb1
Dec 12, 2009 01:34 PM
civiccoupe94
Nov 8, 2007 02:00 PM
AznBlueBoy
Oct 26, 2004 04:33 AM
Ottoman
May 8, 2003 10:01 AM
