Can you figure out what these are?
Old Oct 21, 2002 | 02:17 PM
blackrsx's Avatar
Default Can you figure out what these are?
Hi guys i just recently purchased some injectors off of a 91 eclipse turbo AT, i thought all the turbo dsm injectors were blue tops but these are brown, anyone have any info on the amt of ccs they are?
thanks in advance,
javier
will post pics in a sec...
Old Oct 21, 2002 | 02:21 PM
Jason W's Avatar
Default Re: Can you figure out what these are? (blackrsx)
Here Jav...
Old Oct 21, 2002 | 03:51 PM
Jared's Avatar
Default Re: Can you figure out what these are? (Jasons S4)
whats the number on the side of the injector?
Old Oct 21, 2002 | 04:00 PM
Tegman88's Avatar
usually the blue top injectors are from 1st gen dsm with MT to my understanding? there should be some imprints on the side...mines say inp-009 on one side and b450L on the other
Old Oct 21, 2002 | 04:29 PM
Blackcivic1's Avatar
Default Re: Can you figure out what these are? (Tegman88)
the side reads 35310-33310 and on the other side 9250930011..story is that the local mitsubishi dealer couldnt help us...couldnt find any info in the haynes manual for eclipse's...but they did come from a 90-92 turbo eclipse it was automatic, but after some reserch these injectors are A) Non-oem B) JDM spec??? any other ideas?
Old Oct 21, 2002 | 05:24 PM
racerxadam's Avatar
Default Re: Can you figure out what these are? (Blackcivic1)
if they came from a 90-92 turbo eclipse auto and they say 310 on the side somewhere in the numbers I would think it is safe to assume they are 310s. You could always have them flow tested.
Old Oct 21, 2002 | 05:38 PM
freeplay's Avatar
Default Re: Can you figure out what these are? (racerxadam)
Why is there a + on one side of the DSM blue's? Does the ecu wire have to go to that side? Thanks
Old Oct 21, 2002 | 05:40 PM
xci_ed6's Avatar
only 450s have blue tops.
Old Oct 21, 2002 | 05:47 PM
Default Re: Can you figure out what these are? (Autocratic_1st_Gen)
did they even make eclipses with 310cc's? i have never read that they did...so i guess they could be 390cc? ideas on what kind of shop can flow test? pricing involved?
Old Oct 21, 2002 | 05:48 PM
MiraiZ's Avatar
what about green tops?
trecool44
Jun 10, 2006 04:37 PM
VTteg
Feb 28, 2006 04:20 PM
kr
Feb 27, 2005 07:33 PM
Blackcivic1
Oct 19, 2002 11:37 AM
