WTB: 99 Si Stock Rear Sway
It has to be an OEM Si rear sway, if the part numbers are the same then i would be interested. I can't run any other sway on the car otherwise it'll cost me +2 modification points. I have a comptech 22mm rear sway on the car now, and it doesn't do anything because my rear spring rates are so high. So swapping it out for the OEM 13mm won't hurt the car's performance.
Has to be stock, already running a Comptech 22mm and per the points system it's taking 2 of my modification points away. Can't just remove it, even though I would because it doesn't have any effect on the car due to my 1100lb rear springs. Just trying to gain points back to allow for better and bigger tires.
Snafu-Si
Honda CR-V & Element
10
Aug 10, 2012 09:29 PM
