Small Alternator?
Old Feb 23, 2013 | 11:21 AM
VTEC+Mini's Avatar
Default Small Alternator?
I'm at a loss where this should go to get a good answer. I have a turbocharged B18 with a Hondata S300. I want to replace the current alternator with a smaller one.
There seem to be a million available from Summit Racing...is there a recommended super small alternator that will work? My electrical load is extremely low. Most accessories have been removed.
Old Feb 23, 2013 | 12:14 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Small Alternator?
We just tuned a fox body Mustang that had an extremely small one-wire alternator configuration... Im not too keen on the make of it though. maybe poke around some fox body forums. It was about the size of a large apple.
EDIT: looked alot like this: http://www.ebay.com/itm/NEW-CHEVY-60...131d95&vxp=mtr
Old Feb 23, 2013 | 12:40 PM
bgdriver's Avatar
older d-series alternators are quite a bit smaller than the b-series.
Old Feb 23, 2013 | 03:01 PM
VTEC+Mini's Avatar
I've seen some 6lb Mini one wire alternators that are 45 amp to 60 amps. The case diameter is 93mm or about 3.6 inches and a mounting hole to mounting hole distance of about 5-1/4.
I'm assuming the I can use any 1 wire setup.
Old Feb 23, 2013 | 03:09 PM
Muckman's Avatar
Moderator in Chief
Why not just underdrive it? Ive had bad luck with non OEM alternators.
Old Feb 24, 2013 | 06:43 AM
VTEC+Mini's Avatar
I want to get rid of the size/weight. Some of these alternators are half the size and weight.
Old Feb 24, 2013 | 07:56 PM
post some pics up when you get one all mounted up... i'd like to see it.
Old Feb 25, 2013 | 04:57 AM
VTEC+Mini's Avatar
I definitely will. My only concern is that I have a pair of driving lights and an electric fan to run.
carnot
Sep 15, 2017 02:04 PM
tim_r95
Jan 27, 2015 08:02 AM
ITR198
Honda S2000
Jun 18, 2008 04:13 AM
freeofparanoia
Oct 20, 2003 08:51 PM
