1995 b16 civic help!
Old Feb 23, 2013 | 10:46 AM
RA022326's Avatar
Default 1995 b16 civic help!
I have a 95 civic w/ a p30 that has does not have a check engine light I think the previous owner popped the bulb. I am almost positive that it is throwing some codes, so is there any other way I can check this?
Old Feb 23, 2013 | 10:48 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 1995 b16 civic help!
Check the bulb.
Old Feb 23, 2013 | 11:00 AM
RA022326's Avatar
The CEL bulb?
B_Swapped93's Avatar
yes the bulb it's a size 74 as far as i know. then jump it and let us know the code here's a list:http://check-engine-light-codes.blog...retrieval.html
long blink=10
short blink=1
so:long long short short=22(just an example)
Old Feb 23, 2013 | 12:50 PM
RA022326's Avatar
OK did that but jumping it just made the cel stay on. No flashes what does this mean?
Old Feb 23, 2013 | 12:57 PM
The Grumpiest
Bad ECU possibly. Can you swap it with a known good one?
Old Feb 23, 2013 | 01:10 PM
RA022326's Avatar
No I don't have another one
Old Feb 23, 2013 | 01:26 PM
The Grumpiest
Why were you sure it was throwing codes?
Old Feb 23, 2013 | 02:03 PM
RA022326's Avatar
The way it was using gas and sluggish performance even after a tuneup
Old Feb 23, 2013 | 03:49 PM
Theres MANY things that can cause that(slugishness). Not everything has a sensor/code related to it. Solid cel is ECU/ECM there's a way of going about checking all that. search it or maybe someone can specifly it more.
Old Feb 23, 2013 | 07:31 PM
RA022326's Avatar
Well the CEL stays on now when runnin, but when I jump the 2 pin connector it won't flash the CEL it just goes off
alex97
Apr 27, 2016 10:30 AM
moarlow95ex
Jan 16, 2014 04:00 PM
asiansgoweeee
Jan 1, 2005 11:22 AM
Shorty C
Jan 24, 2004 09:02 AM
smithbling
Nov 19, 2002 12:26 PM
