Honda CR-V & Element 2WD & 4WD Element & CR-V
96 Honda CRV Won't start unless I press the Gas Pedal
Old Feb 23, 2013 | 06:17 AM
nativmd's Avatar
Icon3 96 Honda CRV Won't start unless I press the Gas Pedal
Just bought a 96 crv, when I turn the key it starts then dies unless I press the gas pedal. So far I've changed the spark plugs, fuel filter, and the battery and it still doesn't work. Any help would be appreciated.
Old Feb 23, 2013 | 06:55 AM
Deviant117's Avatar
Default Re: 96 Honda CRV Won't start unless I press the Gas Pedal
Stuck injectors, bad dizzy, stuck IACV, bad TPS
Old Feb 23, 2013 | 07:54 AM
el crapitan's Avatar
start by checking for codes. regardless of an illuminated MIL. if none present, check fuel pressure. if good, check ignition using an HEI tester. if both check out good, service your fitv
Aaron Weise
Jul 9, 2018 09:19 AM
ConfusedHonda
Jun 6, 2013 03:24 PM
motorchap1
Mar 4, 2008 06:10 AM
michjdmeg
Jun 14, 2005 06:44 PM
