b20v
Old Feb 22, 2013 | 06:05 PM
Manny-Em1's Avatar
Default b20v
any one have an estimate of how much whp ill be pushing?
my set up:
0 miles b20b4 block
compression is 11:5:1
84.5mm
head is stock out of my em1 [b16a2]
i have type r intakemanifold
dual springs
obd1 chipped
2.50 tri y headers
password jdm intake
Old Feb 22, 2013 | 06:08 PM
EsotericImage's Avatar
Retired Moderator
Default Re: b20v
Old Feb 22, 2013 | 06:55 PM
1998GsRIntegra's Avatar
Default Re: b20v
Old Feb 22, 2013 | 06:57 PM
hybridmiklo's Avatar
Default Re: b20v
hold on. let me put this in my horsepower calculator
Old Feb 22, 2013 | 07:23 PM
DDTECH's Avatar
Default Re: b20v
180.
Old Feb 22, 2013 | 07:39 PM
grumblemarc's Avatar
The Grumpiest
Default Re: b20v
1,000,000 horsepowers!!!
Old Feb 22, 2013 | 08:09 PM
raverx3m's Avatar
Default Re: b20v
crank horse or wheel horse
there are many honda forums
and EACH ONE has a dyno section
including this forum
theres ALL MOTOR DYNO thread here just above your post
chances of you finding a very similar if not identical setup are about 99.99999%
Old Feb 22, 2013 | 08:10 PM
raverx3m's Avatar
Default Re: b20v
now i can see why i got so much **** for asking these questions when i first started building my engine.
Old Feb 22, 2013 | 08:32 PM
TGonie's Avatar
Default Re: b20v
My setup was similar at one time. except 84mm and ctr cams. 183whp on a dyno jet
Old Feb 22, 2013 | 08:40 PM
B_Swapped93's Avatar
Default Re: b20v
^lol
Get some cams in there op you got the springs(still need reatiners) but with that comp you could get some S2 tuner 3's. Or bump the CR a bit more and go PRO 1. most likely 170-180whp ?
Old Feb 22, 2013 | 11:29 PM
93geezr's Avatar
Default Re: b20v
Old Feb 23, 2013 | 12:50 AM
si_coupe's Avatar
Default Re: b20v
I'm sure there is an All Motor dyno thread at the top of the page. Take a look it'll give you an idea.
Old Mar 2, 2013 | 07:04 AM
EusebioSam19's Avatar
Default Re: b20v
120 flywheel horsepower 77lb tq
Obd1 chipped sounds like a basemap to me.
He didnt even say cams which makes me believe he's running stock b16 cams
And probably trying to rev that out to 8000-8500k
Scott A
10
Apr 25, 2014 09:01 AM
hondalectual
22
Feb 3, 2010 11:11 PM
TurboTegB18c
54
May 24, 2007 05:53 PM
Frog
15
Jul 18, 2003 05:02 PM
WAFFLES
Mar 28, 2003 08:02 AM
