cluster frustration!! please help!
Old Feb 22, 2013 | 04:06 PM
CRX-CHACE's Avatar
Icon2 cluster frustration!! please help!
I haven't posted in a while, but since my last post I have gotten my crx running. Although it is running I am having a few problems!
1. My first problem is that the only gauge on my cluster is my Speedo. A while back my tach would randomly work for about 30 seconds after starting my car then it would stop. It would also sometimes stay around 1k rpm and it would fall to zero when I would hit the gas?? I tried re wiring the cluster using a diagram I found on this website, now it never moves at all! My temperature gauge never works and never has. My temp gauge seams to slowly go up or down as I'm driving but it has absolutely nothing to do how much gas I have, usually it slowly moves up???? My cluster lights do not work as well.
INFO ABOUT CAR (USEFULL?):
-When I got the car there were no grounds in the engine bay. I added one from the valve cover to the frame and from the tranny cable bracket to the frame. Am I missing any?
- it has an incomplete mini me swap, it has a d15b2 bottom end and a y8 or z6 head(how do I tell?). It still has the pm6 ecu
Does ANYONE any idea what's going on here?
PLEASE PLEASE HELP! I'M SICK OF NOT KNOWING IF MY CAR IS OVER HEATING AND I'M SICK OF SHAKING MY CAR TO SEE IF I HAVE GAS!
Old Feb 22, 2013 | 07:25 PM
CRX-CHACE's Avatar
Default Re: cluster frustration!! please help!
Bump, please people!
Old Feb 23, 2013 | 01:07 PM
mike205's Avatar
There should be a ground on the thermostat housing
And from what your describing on your gauge cluster mine was doing the same thing
I ended up replacing the cluster and it fixed my problem
Old Feb 23, 2013 | 01:45 PM
CRX-CHACE's Avatar
Can you possibly post a picture of the thermostat ground? And possibly the a picture of your cluster pinouts?
Old Feb 25, 2013 | 05:21 AM
mike205's Avatar
I can get you a pic of the Thermostat housing I'll try to get a pin out of gauage
Old Feb 25, 2013 | 07:05 AM
myefhasaname's Avatar
A couple ways to tell about your head. Google some pictures of z6 and y8 heads you will notice the vtec is on different sides be it the intake or exhause side. Another way is the intake manifolds. Though this will not be a 100% gurantee usually you will find y8 manifolds with y8 heads. You can aslo google up some pictures of those. You will notice the y8 has angled pipes connecting it to the block while the z6 has straight pipes
Old Feb 25, 2013 | 10:00 AM
CRX-CHACE's Avatar
Icon3 Re: cluster frustration!! please help!
Thankyou sir!
and i found the code for a y8 on my head. people claim that z6's are the way to go. but from what ive heard i would rather have mid range power
Old Feb 25, 2013 | 10:01 AM
CRX-CHACE's Avatar
also i will be buying a cluster this week so i hope that solves the problem!
Old Feb 25, 2013 | 10:35 AM
CRX-CHACE's Avatar
I have couple more questions involving the mini me swap. since i still have the obd0 ecu and dizzy what ecu and dizzy do i need? for example can i use a z6 dizzy with my y8 head? or a z6 ecu? do the ecu and dizzy have to match each other? do they have to match the head? once i get the new ecu and dizzy do i just need a jumper harness??
Old Feb 25, 2013 | 08:23 PM
mike205's Avatar
I have a few clusters I can sell if your interested let me know and I'll send you my number
Also going to try and get pic tomorrow if it doesn't rain
Old Feb 27, 2013 | 08:35 PM
p28 is always a solid choice and it leaves a lot of options open later on if you chip it.
Old Feb 27, 2013 | 10:35 PM
CRX-CHACE's Avatar
Can you use a p28 with a y8 dizzy or do you need a z6 dizzy to match the p28?
Old Feb 28, 2013 | 08:03 AM
stackedhouse's Avatar
Yes you can use a p28 with any obd1 or obd2 dizzy, you'll need a jumper harness for the Ecu and either a jumper harness or you'll need to hardwire the plugs for the dizzy
Old Mar 1, 2013 | 09:47 AM
CRX-CHACE's Avatar
An obd2 dizzy? Really? Thanks for the reply
MTarry
11
Jan 15, 2013 06:46 PM
Awndre671
Sep 25, 2011 08:33 AM
Blue00Si
Nov 2, 2007 07:33 AM
tommy.
12
Aug 29, 2006 05:27 PM
