brakes & rotors for 96 spec?
Old Feb 22, 2013 | 06:19 AM
UKDC2FOORPLAY's Avatar
Default brakes & rotors for 96 spec?
were can i find them or what car can i use them from any info would be appreciated
Old Feb 22, 2013 | 07:34 AM
silent112's Avatar
10 Year Member
Default Re: brakes & rotors for 96 spec?
fastbrakes.com has some in stock, I've heard the pads are the same as a gsr or type r here
Old Feb 22, 2013 | 08:38 AM
teg97's Avatar
You can use US ITR front calipers and 92-95 prelude vtec rotors
the rear are ITR rear calipers and 90-93 accord rear rotors.
but that's if you want a brake upgrade. Fastbrakes sells rotors as well
Old Feb 22, 2013 | 10:35 AM
thanks for info . does anyone know if nsx calipers would bolt up?
Old Feb 22, 2013 | 11:07 AM
teg97's Avatar
I think nsx would bolt up using usdm ITR caliper brackets. not completely sure on that
Old Feb 22, 2013 | 01:01 PM
cvcrcr99's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/definitive-1996-honda-itr-brake-setup-part-list-3088984/
Old Feb 22, 2013 | 02:15 PM
Thanks ^
Old Feb 22, 2013 | 02:32 PM
What do you guys recommend as a good strut / spring combo nothing crazy 300-500
Old Feb 23, 2013 | 06:25 AM
cvcrcr99's Avatar
Probably best making a new thread, or doing research on that. No one is expecting to see new questions about suspension when your thread and OP are referring to brakes.
With that said, Koni/GC are favorites
Old Mar 11, 2013 | 10:20 PM
mkhalid's Avatar
so I need new rotors for my Spec 96 as well, so can I get the accord rear and use my current 96spec calipers?? Or do I have to also get the 01 ITR calipers if I want to use the 93 accord rear calipers/ prelude v-tech rotors? Thanks.
Old Mar 14, 2013 | 07:04 AM
cheezthis's Avatar
https://honda-tech.com/forums/acura-integra-type-r-8/jdm-96-spec-rear-brake-usdm-98-spec-2764996/
That's an old thread of mine detailing how to go from 96 spec to 98 spec/USDM ITR/NSX/etc. while retaining 4x114.
Old Mar 14, 2013 | 09:05 AM
cvcrcr99's Avatar
Read:
https://honda-tech.com/forums/showthread.php?t=3088984
OEM 94-01 Non-ITR Teg pads and re-drilled rotors or fastbrakes.com, or swap to something else. Brakes are cake compared to replacing rear wheel bearings and finding replacements for those. Ask me how I know.
Old Mar 14, 2013 | 12:34 PM
mkhalid's Avatar
okay thanks!
DC2R82
Mar 27, 2012 12:08 PM
silver97hatch
Suspension & Brakes
12
Mar 27, 2009 09:42 PM
tnd2gen
Jul 17, 2004 07:58 PM
nickwilmot
Sep 5, 2003 12:00 PM
