D15b7 engine build
Old Feb 21, 2013 | 04:38 PM
BakyardBrokanic's Avatar
Default D15b7 engine build
Been spectating Honda-tech for years never posted but helped me a lot with many of my projects I had, anyway down to the gritty, planing to build a D15b7 that I have on the side here are the parts list i think should be alright with what I am trying to do.
D16y8 head reconditioned
D16y8 5 speed intake manifold port matched to 68mm.
Blox Racing dual valve springs
Blox Racing retainers
Blox tuner series stage 2 or 3 Sohc Vtec camshaft
Adjustable cam gear
Aem fpr
D15b7 block rebuilt fitted with PG6 (US 86-87 D16A1) pistons
ARP rod bolts
12lbs Aluminum flywheel
Any name brand stage 1 clutch
Only thing popped in my head was the pistons that I am using has anyone used it on a d15b7? Camshaft selection stage 2 or 3's? I am leaning towards stage 2's for DD. Are Phearable ecu's okay to use? Before i shell out an Hondata s300 later on. Please guys need some input on this build nothing serious in mind but just want it a bit faster and reliable for years.
Old Feb 22, 2013 | 06:10 AM
strategy400's Avatar
Default Re: D15b7 engine build
Someone makes rods for this... is it Crower? Rumor has it the B7 have weak rods.
Old Feb 22, 2013 | 10:56 AM
94EG8's Avatar
Seagull Management
I just checked it on the compression calculator. They *should* work ok. A little over 10:1 compression.
Old Feb 26, 2013 | 03:56 AM
slowDB7's Avatar
the rods wont be a problem, with it being n/a stock b7 rods breaking point is 200 hp
but yes crower and cx racing both make rods for it.
cams-go with stage 2 for now you can always upgrade to stage 3 later
usually people run the p29 piston in their b7s, but i dont know much about the pg6 pistons in the b7
ecu- Phearable is a good company to get the ecu from
and get the arp head studs and rod bolts
Adquick8
May 21, 2019 06:19 PM
tshuajzoo559
Northern California (Sales)
Sep 6, 2008 03:41 PM
builthatch
Northeast (Sales)
Aug 7, 2007 01:06 PM
