Do both Gen. Acura CL's use same Head?
Old Feb 21, 2013 | 01:22 PM
JamesB1985's Avatar
Default Do both Gen. Acura CL's use same Head?
Im Re-Building my 1998 Acura CL 3.0 engine and I had to replace the rear cylinder head. The engine code is J30A1. Now I bought a rear J30A1 cylinder head off EBAY but I didn't see that it was for a 2001-2003 Acura CL J30 engine.
The cylinder heads look identical inside and out but have different casting code/numbers. I installed the head with my old camshaft and rocker arms but now Im trying to install the timing belt and I can't get the rear cylinder head camshaft pulley to line up with the mark on the backing plate for the TDC marks???
I have the Crank gear lined up TDC and the front cylinder head pulley at No.1 TDC but when I turn the rear camshaft pulley it won't line up with the backing plate... I turn the bolt on the pulley with a socket and it turns but as it comes down the camshaft lobe it spins right past the TDC mark??? Im a little confused... Thank you!
Old Feb 22, 2013 | 05:36 PM
WHEEELMAN's Avatar
Default Re: Do both Gen. Acura CL's use same Head?
Your 98 CL has a J30A1....which was also transplanted into the 98-02 Accords.
The 01 - 03 Acura CL has the J32A2
-- Different heads --
You need a J30A1 head from 97-99 Acura or 98-02 Accord.
redline870
Sep 15, 2009 10:51 AM
Tippyman
May 18, 2008 03:07 PM
Tippyman
May 16, 2008 09:42 PM
Tippyman
May 16, 2008 07:53 PM
Tippyman
May 16, 2008 07:48 PM
