limp mode at WOT
1990 Crx DX auto originally
Obd1 Gsr swap running chipped P28 from phearable.net car runs great except for one issue. It hits a brick wall at WOT.
When accelerating it acts completely normal until throttle is opened all the way. Whether i pound it down or gently caress my foot into it, the reaction is always a complete loss of power and violent bucking.
I put a clear tube on the vacuum line for the fpr while someone worked the throttle. i saw fuel coming through the vacuum at wot. Should i replace the fpr? Would that cause this issue?
Any speed any rpm and even just from idle.
Do you have a non-chipped ECU to try?
Even a stock P28 might work... it will run a bit lean so I would suggest only to see if the bucking is still there.
HITECVTEC
Aug 16, 2018 09:08 PM
si0385.
21
Apr 15, 2007 07:11 PM
