Signs of a bad water pump?
Old Feb 20, 2013 | 08:19 PM
raider1qaz's Avatar
Default Signs of a bad water pump?
Previous owner thought i needed one, not to sure if i do.Any signs or a bad one?
Old Feb 20, 2013 | 08:39 PM
Marvin1985's Avatar
Default Re: Signs of a bad water pump?
Is it leaking? When they go bad they leak.
Old Feb 20, 2013 | 08:51 PM
Former User's Avatar
This^ They typically leak from one or both weep holes.
Old Feb 21, 2013 | 07:06 AM
strategy400's Avatar
You can also open the radiator cap on the cold car, warm it up to operating temp (cooling fan comes on), and then rev the engine while observing if there is a healthy flow of coolant in the radiator (flow being the purpose of the pump and the result of all properly operating devices in the cooling system). Keep in mind to use caution around an open radiator with scalding hot coolant lest the scalding hot coolant leaps out from said radiator and burns your eyes from their sockets. Also, while you're at it, look for excessive bubbling of exhaust/combustion gasses in the radiator neck, indicating a possible bad headgasket. If in doubt and to be sure you can purchase a block tester from your local autoparts store and test for combustion gasses in the radiator.
DevonsHonda
Dec 20, 2013 05:40 PM
freshgear
Jul 19, 2009 01:48 PM
dc4drewH
May 22, 2006 01:06 PM
bigslimdog
Aug 10, 2004 03:37 PM
dbman96
Aug 8, 2001 02:24 PM
