cleaning up. over 70 different items FS. eg crx integra ek b16 LS sohc rsx ef
cleaning up so getting rid of what i can.
it took forever to make this thread, tomorrow i will add prices and i have a few more things i need to get pics of.
a lot of these things would be better off picked up rather than shipped
all parts located in freeport, illinois
thanks for looking!
knock off steering wheel
eg carbon fiber gauge pod
crx passenger window regulator (i believe i have two of these)
crx battery tray
88 crx gauge cluster cover (painted green by PO, could be stripped to normal condition)
88 crx kick panel
eg wiper motor
crx cluster (PO installed overlays)
fake carbon fiber tach, changes colors
oem eg LCA's
everything for front integra brake conversion (needs new rotors and pads obviously)
little panel of crx by where the bottom of fender and door are, i think its off the left side
eg camber arms
crx ac bracket
crx ac compressor
eg clock block off
crx ac receiver dryer
b series bracket
rear mount bracket
b series engine mount
b series half shaft
stock eg spoiler
apex can
eg fogs
crx rear strut interrior pieces (paint is coming off from the PO)
intake with k&n filter
crx/del sol chilton manual, beat up but everything is in there
15in montegi MR7's 3 sandblasted, one needs sandblasted, all need paint
crx ac condenser
shaved eg trunk
ek front bumper
ek rear bumper, has a crack
ef front bumper
eg trunk
DASHES
1 ef dash
1 ek dash
2 integra dashes
$100 each
eg passenger door interior
14 in hub caps
eg mirrors, 1 has cracked glass
rsx fuel pump
b series starter
non vtec valve cover and head
golden eagle ls vtec kit
two stock LS pistons
drilled and slotted RSX discs and ceramic pads
eg rear side plastics
LS head parts
parts off of LS block
rsx sway bar
LS valve cover
brake booster
fuel rail and injectors from LS, i think
b series block brackets
more random brackets
b16 and LS water pumps
b16 oil return
sohc exhaust manifold
blox cai
another b series fuel rail with injectors
crx passenger door with seatbelt
crx hatch
new sohc spark plug wires
LS oil pan
thanks for looking!
crx battery tray
88 crx kick panel
eg wiper motor
oem eg LCA's
eg camber arms
crx ac bracket
crx ac compressor
eg clock block off
b series bracket
rear mount bracket
b series half shaft
stock eg spoiler
apex can
eg fogs
crx ac condenser
shaved eg trunk
ek front bumper
ef front bumper
eg trunk
DASHES
1 ef dash
1 ek dash
2 integra dashes
$100 each
14 in hub caps
rsx fuel pump
b series starter
LS head parts
rsx sway bar
LS valve cover
brake booster
b16 oil return
blox cai
crx hatch
LS oil pan
shortA25
Dec 13, 2012 07:27 PM
frostwhite_92
Mar 8, 2005 02:50 PM
IDriveHonda
Jan 2, 2004 08:13 AM
