integra inner stand off bolt snapped off
Old Feb 20, 2013 | 11:20 AM
btlb88's Avatar
Default integra inner stand off bolt snapped off
i was installing the skunk2 low pro valve cover studs i over tighten 3 of the 4 inner stand off stud in side i was wondering if you guys can help me figure out a way to get it out here a picture
Old Feb 20, 2013 | 11:23 AM
Todd00's Avatar
I said I don't want a title!
Default Re: integra inner stand off bolt snapped off
So the Junk2 studs broke off?
Classic.
Otherwise, remove it like you would any other snapped-off bolt.
Old Feb 20, 2013 | 11:29 AM
btlb88's Avatar
Classic.
it said 20lb and i read it wrong and out it to 70lb and i dont know how remove them
Old Feb 20, 2013 | 04:53 PM
Dogginator's Avatar
Daisy... Daisy...
Try a screw extractor.
Old Feb 20, 2013 | 04:55 PM
powercreator's Avatar
Classic.
Guy posts he over tightened the bolt and you bash the company for his mistake?
Classic.
Old Feb 20, 2013 | 04:56 PM
Extractor should do the job. Good luck!
Old Feb 20, 2013 | 05:47 PM
shifts's Avatar
Those damn bolts are too sensitive.
I had this happen to me and I was fortunate enough to be able to just use some vice grips. Take the entire rail off and and inspect to see if there is enough of the bolt to grip.
I thought of a screw extractor but I was afraid to get some shavings into the head, I suppose you could just put rags around the bolt?
Old Feb 21, 2013 | 09:59 AM
citrus3000psi's Avatar
I worked on friends integra with this very same thing...He over tightened them all. About 7 of them snapped. I was able to extract most of them with ease with a bold extractor. Just make sure to use a high quality kit. If you've ever snapped a cheap bolt extractor bit off, its about impossible to drill out.
Old Feb 21, 2013 | 11:39 AM
Todd00's Avatar
Classic.
That's because that "upgrade" is a complete ricer mod.
Perhaps he was going for Skunk2 certification though. lol.
Now that would be classic.
P.S. Skunk2 sucks as well.
Old Feb 21, 2013 | 07:15 PM
1998GsRIntegra's Avatar
Awwww yeaaaa you go hard if you're "skunk2 certified" Lmfao. If one of their **** quality throttle bodies hadn't destroyed one of my engines maybe I wouldn't hate them so much.
Old Feb 22, 2013 | 05:52 AM
ekcoupeh22's Avatar
Classic.
bash a company because a backyard mechanic doesnt know what hes doing? wow ive run skunk2 parts for years with no problems and so has thousands of other people
Potential2nr
Jan 17, 2012 03:47 PM
00DC2
Jul 22, 2009 06:18 PM
Yelowfever
Jul 10, 2007 08:06 PM
jadugartir
May 23, 2005 10:44 AM
