22 Mpg with 96 Civic Dx Automatic??
Old Feb 19, 2013 | 07:53 PM
raider1qaz's Avatar
Icon3 22 Mpg with 96 Civic Dx Automatic??
Is that normal?? i drive city and highway. I've changed the oil, air filter,spark plugs/spark plug wires, thermostat ,fuel filter, head gasket.Any ideas why? Any tips to get more MPG because gas here is $3.35-$3.50
Old Feb 19, 2013 | 08:23 PM
CO671's Avatar
Default Re: 22Mpg with 1996 Honda Civic Dx Automatic??
It's an 18 year old vehicle, even with tune-up's you won't be getting the same mileage.
The best you can do next with what you have on the vehicle now would be a suspension/steering alignment, and balancing tires.
No need to look into changing your octane (that'll cost more in the long run)
If you want to be achieving 35-50mpg, then get another vehicle.
Old Feb 19, 2013 | 08:45 PM
LongLiveMoon's Avatar
Monthly air checks in your tires help. Most doors say 32psi inside but run at 35psi. Hope this helps.
Old Feb 20, 2013 | 12:09 AM
fasterthanueg's Avatar
Plain and simple the automatics get crap milage. My 97 auto ex gets 22-28 and gas is alittle higher here in wa
Old Feb 20, 2013 | 01:23 AM
fleabag's Avatar
22mpg is horrible for this vehicle 18 years or 35 years! This guy has some work ahead of him! The only reason why an older vehicle would get worse fuel economy purely due to age and not lack of maintenance is from weak valve springs and piston rings but even if the car were burning oil badly and was on its last legs, assuming EVERYTHING ELSE is working properly, it shouldn't be getting 22mpg. I.e. perfect fuel mixtures, idle control, etc. etc which I doubt this car has that problem. A bad transmission would cause this issue but I don't think OP has that problem either as I'd think it'd be noticeable. what kind of spark plugs are you using op? clean up your electrical grounds and report back. there are a ton of grounds to clean up on a car of this vintage.
Old Feb 20, 2013 | 05:19 AM
Former User's Avatar
Also replace the cap and rotor and check/adjust the ignition timing.
Old Feb 20, 2013 | 12:55 PM
DennisH's Avatar
Default Re: 22 Mpg with 96 Civic Dx Automatic??
Older or not, the 22mpg truly is horrible. My friend must have been getting at least 27-28mpg and his is the same car (maybe it was an ex even?).
Definitely check the pressure in the tires, alignment is good, check if your exhaust isn't clogged either.
Old Feb 20, 2013 | 12:59 PM
furious94ls's Avatar
As far as your tune up, if you didn't use OEM parts that's also a reason for poor fuel economy.
Alignment, tire size, tire wear, and inflation play a big role in mileage. Fresh clean fluids help too. I've managed 38mpg on a 98EX with 200k automatic.
Old Feb 20, 2013 | 01:16 PM
fleabag's Avatar
Well he doesn't have to use OEM parts but should use their equivalent... I.e if the car came with Bosch from the factory, use Bosch... In the case of Hondas, they use either Denso or NGK, likely NGK as Denso is more of a Toyota Thing.
Maybe we can get some confirmation here on who made the cap+rotors and wires for Honda Civics of this vintage...
Old Feb 20, 2013 | 08:14 PM
raider1qaz's Avatar
the stuff ive replaced i used quality products , my tire pressure is on point
Old Feb 21, 2013 | 05:03 AM
chief8000's Avatar
i just bought a 96 cx hatch thats an automatic hoping for good gas mileage but on my last tank I only got about 25. every thing is completely stock on mine except some ebay sri the previous owner put on. I bought a stock intake and going to put it on and see if it help any I would say 80% of my driving is highway.
Old Feb 21, 2013 | 06:23 AM
94EG8's Avatar
Seagull Management
Wires were normally made by Sumitomo. (some Accord wires IIRC were made by Prestolite) NGK wires are about the only aftermarket wires I'd used, they're very similar construction to OEM, but if you buy online or get a deal at your local dealership the price is about the same an NGK anyway. Caps are made by Tec.
Old Feb 21, 2013 | 07:25 AM
strategy400's Avatar
I'd also suspect the ECU is not getting proper feedback from its sensors in regards to engine coolant temperature (not warmed up), exhaust emissions (o2 sensors), any number of other sensors that are malfunctioning/not responding or that it has a check engine light (CEL) on or the ECU has thrown some error code resulting in the ECU using a default basemap, any or all of which could result in the ECU providing too much fuel (a rich mixture) to the engine.
How do the spark plugs look?
Assuming none of the above, do a major tune up, including valve adjustment, plugs, wires, cap and rotor (I see you've already done some of this). A compression test will also reveal the condition of the combustion chambers (easily accomplished while changing the plugs).
Old Feb 21, 2013 | 07:28 AM
I get 35-38 in my heavy *** 4 speed auto del sol. It cost me $40+ to fill up yesterday.
philliesfan11
Honda Civic (2006 - 2015)
11
Sep 28, 2017 03:14 AM
js74
22
Mar 25, 2010 10:36 AM
Revolver123
Honda Civic (2001 - 2005)
Jun 11, 2008 08:45 AM
SIDEXIT
Jan 10, 2008 02:22 PM
ROK801
30
Sep 9, 2005 09:57 AM
