89 ef cv axle problem
So I have changed both cv axles in my brothers ef the right side is perfect but the left side I am having trouble with. When I go to tighten the axle nut it seizes up the hub and I have not tightened it anywhere near the torque spec of 134 ft lbs. I had the wheels studs replaced and the wheel bearings on both sides but this issue is only on the left/drivers side hub and axle. I have done many cv axle replacements so I am not a noob to this. I just can't for the life of me figure this out I have taken it apart and put it back together since finding out about this issue. If anyone has any input on this it will be greatly appriciated.
