turbo timer issue
Old Feb 18, 2013 | 07:36 PM
ncsi's Avatar
Default turbo timer issue
So I wired a hks turbo timer in my 90 integra and for some reason it works other than keeping the car running lol. The timer turns on reads voltage, rpm and even times out when i put the ebrake down but does not keep car running after key is turned off run.....what could cause this? I have 12v constant on white wire. 12v on black/yellow and yellow with ignition on. Should yellow wire have 12v on with accessory on?
Old Feb 19, 2013 | 06:51 AM
fcm's Avatar
fcm
Old Fart
Default Re: turbo timer issue
The leads you need are the white, 12V+ hot at all times, [ign. switch power] and the black/yellow, [ign.1] power, [hot in run and start] and possibly the blue/white, [ign.2] power, [hot in run] if you have the blue/white 2nd ign. lead.
what model HKS turbo timer do you have? 94
Old Feb 19, 2013 | 08:01 AM
ncsi's Avatar
red goes to white wire on ig harness green goes to yel/blk wire on ig harness blue goes to yellow wire on ig harness
black wire goes to ground
gray wire goes to handbrake wire
brown goes to rpm
Other blue which goes to speedo is just capped off.
Its a 8th gen hks full auto timer
Old Feb 19, 2013 | 12:05 PM
fcm's Avatar
fcm
Old Fart
Did you mean, green goes to black/yellow, [ign.1]?
Blue to yellow, yellow is the acc. lead, you should not need that for the timer, however there is a blue/white, [ign.2] that you may need, move the blue to the blue/white and see if that works...
http://www.the12volt.com/installbay/...etail/146.html 94
Old Feb 20, 2013 | 12:43 PM
ncsi's Avatar
Still the same thing
Old Feb 20, 2013 | 01:50 PM
fcm's Avatar
fcm
Old Fart
Confirm you have power on the green and blue leads of the timer when it is on. 94
Old Feb 20, 2013 | 07:14 PM
ncsi's Avatar
Im gonna say screw the turbo timer for the time being....im having a big issue now. Car wont run....
I had it on and off quite a few times today testing the turbo timer. Well ive done it before with no flooding issues. Was looking through wires on ecu for speedo wire(only touched wires) and then car wouldnt start. It is a obd1 converted 90 integra with a moates demon in a p72 with a tunerview rd1 cluster. Well the car primes, the main realy clicks twice but when i go to start the car it turn over runs for a second then shuts off. I pulled the plugs they are fouled it flooding. Also noticed my cel doesn't come on with ignition on....
Old Feb 21, 2013 | 06:48 AM
fcm's Avatar
fcm
Old Fart
Sounds like ECU/ECM problem, injector pulse too long or staying open. 94
Old Feb 21, 2013 | 09:11 AM
n*werk's Avatar
sound like you don't know what your doing. i would check your ign. wires. You did say you hardwire it in correct? that can cause a shortage. more info would be great.
Old Feb 21, 2013 | 10:24 AM
ncsi's Avatar
Sounds like you should not post on my thread! It was hardwired and there was something wrong with that turbo timer because I had my buddy's type 0 wired in and it worked. Really no difference between a harness and hard wiring it just more work..btw what its doing now was with the timer wired and still doing it with it taken off.
Old Feb 21, 2013 | 10:52 AM
fcm's Avatar
fcm
Old Fart
I was going to ask how hardwiring would cause a short. 94
jnemci
Jan 11, 2010 06:16 PM
TheCivicMafia
Audio / Security / Video
Sep 1, 2009 07:34 PM
nocturnal EG
16
Nov 3, 2006 08:04 AM
mooook
Dec 31, 2004 12:26 PM
skyman88
Jul 19, 2004 11:32 AM
