Old Apr 1, 2015, 09:29 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
96 Civic door panel removal from rear door that won't open?
Old Feb 18, 2013 | 05:57 PM
raider1qaz's Avatar
Icon3 96 Civic door panel removal from rear door that won't open?
My door wont open and i wanna know why so i want to take off the panel and tips?
Old Feb 18, 2013 | 05:58 PM
Former User's Avatar
Default Re: 1996 Honda Civic rear door panel removal?
I believe that you can remove the panel of the closed rear door if you remove the rear seat.
Old Feb 18, 2013 | 07:02 PM
raider1qaz's Avatar
Default Re: 96 Civic door panel removal from rear door that won't open?
I can open the door if i take the handle from inside and pull on the metal bar thats attached to it
Old Feb 18, 2013 | 07:04 PM
I'm not following you. Why not remove the door panel so that you can figure out the door latch issue? Is the child protection lock on?
Old Feb 18, 2013 | 08:27 PM
raider1qaz's Avatar
when i got my car the doors work,then one day i put the child lock on and now it doesn't open from the inside or the outside but i can get it open if i pull the metal rode that's attached to the inside door handle..i got the door open and turned the child lock off and still have the same problem ,still won't open from either side
Old Feb 18, 2013 | 08:47 PM
Remove the door panel and post pictures of the child lock mechanism. It's probably faulty - stuck on.
Old Feb 18, 2013 | 08:53 PM
raider1qaz's Avatar
alright i will tomorrow if i cant get it myself, maybe something is stuck or loose or fell off.thank you
Old Feb 19, 2013 | 01:36 AM
MRGRIM's Avatar
R.I.P. Mark
when you do have it open you can use a screw driver to latch the lock on the door while testing it
pust the screw driver shaft into the lock "just like the door latch plate rod"
Old Feb 19, 2013 | 08:35 AM
slcivic's Avatar
If the rear door is not opening from the outside you probably have a broken bush joint which part 3 in the diagram below. This part is attached to a rod which connects the door handle to the door lock. A new one costs about four dollars from Honda, it seems from my research and experience that this part commonly breaks on our 4 doors. Good Luck
Old Feb 19, 2013 | 01:43 PM
raider1qaz's Avatar
i fixed it today, the part 27 came undone and i put it back and works fine now, thank you everyone
wallytucker
Honda Civic (2001 - 2005)
Aug 6, 2017 03:21 PM
1yesfan
Apr 30, 2015 08:31 AM
george1960
Jun 17, 2013 04:01 AM
kkulseth
Jun 26, 2007 07:21 PM
USDM DC4
May 19, 2007 06:19 PM
