no spark no fuel
Old Feb 18, 2013 | 11:25 AM
91 EF DX's Avatar
Default no spark no fuel
I picked up this sedan for cheap. The body was in pretty good condition but the guy told me it didn't run and didn't know why. So I got it home and started messing with it and found out it needed a new gas tank. So i replaced the gas tank. And tested the fuel pump while i had it out. I ran good. Put it all back together and not getting fuel or spark.
Ive put in a known working dissi, ecu, and main relay so i know for sure its no that. Anybody got any ideas as to y im not getting any spark or fuel. And btw it has new ngk plugs and wires.
Old Feb 18, 2013 | 11:44 AM
Former User's Avatar
Default Re: no spark no fuel
Car and engine?
Check all three main relay fuses and the G101 ground on the thermostat housing.
Old Feb 18, 2013 | 12:22 PM
91 EF DX's Avatar
91 lx civic. stock dual point d15b2 in it. Cleaned the ground. that was the first thing i thought of. There is a plug thats been cut off the harness that plugs into a sensor on the head right under the dissi. I think its the temp sensor? Which fuses are the 3 main ones? i checked the ones under the hood they are all good.
Old Feb 18, 2013 | 12:26 PM
Three main relay fuses:
15A hood ECU fuse
10A dash fuse 14
10A dash fuse 2
Voltage check them - click link in my signature.
What color and number of wires does the unplugged connector have?
If you reset the ECU and then crank the engine for 25 seconds, what CEL codes are thrown?
Old Feb 18, 2013 | 12:30 PM
skill178's Avatar
yea, under the dizzy is the temp sensor for the gauge (1wire) and for the ecu (2wire)
check for any broken wires going to the dizzy, otherwise see if you can try another dizzy or ecu. are the replacement ones you tried for a dp or mp engine? ive seen a lot of people interchange them and then realize it don't work. if none of that or the forementioned fuses work grab a intake and go mp lol.
Old Feb 18, 2013 | 12:50 PM
91 EF DX's Avatar
thats was it!!! now shes running like a champ. thanks man
Old Feb 18, 2013 | 12:51 PM
Originally Posted by 91 EF DX
thats was it!!!
What was it?
Old Feb 18, 2013 | 12:57 PM
skill178's Avatar
Icon7 Re: no spark no fuel
Originally Posted by RonJ@HT
What was it?
Old Feb 19, 2013 | 09:07 AM
91 EF DX's Avatar
It was the dash fuse 14. It was blown. Replaced it and everything works. She is running strong now.
keslerbuilt
Jan 26, 2014 09:50 AM
slowassciv33
10
Jul 1, 2007 04:04 PM
mihaelrosas
Jun 8, 2007 04:27 PM
slvrcvc93
Apr 24, 2007 11:27 AM
1QwIkEf
Jan 10, 2005 08:15 PM
