91 D15 block/99 D16 head mini me swap - won't run
so i recently did a mini swap and car started but wont run the only thing i can thing of is i forgot to pull out the plug on the new head before i put it on would this cause the car not to run
91 civic 1.5l
99 civic head 1.6l
1.6l belt
obd0 dizzy
obd0 ecu ps9
resistor box
240cc injectors
car started ran for 2 min died wont start anymore. any other ideas also will help
91 civic 1.5l
99 civic head 1.6l
1.6l belt
obd0 dizzy
obd0 ecu ps9
resistor box
240cc injectors
That won't cause it not to run. That is the oil control jet. It should at least run even with it in place, although if u think you forgot to pull it out you really need to pull the head back off and double check.
Posted from Honda-tech.com App for Android
if you mean to plug between the block and the head it will run fine with no problems but vtec will not work. the 99 head is it a y7 or y8? and it would be a good idea to purchase and install obd1 dizzy and ecu.
auto or 5speed?
I ask because that's an auto ecu. but should still run,
NOW. big question, you say its a obd0 dissy meaning it will not bolt up correctly and will need to be modified or else it will be extremely far off on the ignition timing.
pay no attention to the red circles its a recycled image.
can you post a image of your dizzy bolted to the head?
auto or 5speed?
you can grind the lobes to make it fit, turn it till itll start with no bolts and youll see where it needs to be. (notice the notch in the right dizzy on the pic)
would be best to get the car running obd1 with a obd1 dizzy and ecu. but you can run the old if you notch it
is the car dpfi? or already been converted to mpfi? (d15b2) or actually d15b?
D15B
Found in: 1988 Honda CRX 1.5X (rare)
1990 Honda Civic 25XXT Formula (Japanese Market)
Honda Civic Ferio MX (Japanese Market) EG8
1998–2001 Honda Capa GA4 (Japanese Market)
D15B VTEC
Found in: 1992–1995 Honda Civic Vti (Japanese Market)
1992–1998 Honda CRX DelSol (Japanese Market)
D15B 3-Stage VTEC
Found in: 1995–1998 Honda Civic Ferio Vi (EK3, Japanese market)
1999-2000 Honda Civic Vi-RS
D15B2
Found in: 1988–1991 Honda Civic GL/DX/LX
1988–1991 Honda Civic Wagon Wagovan/DX
1988–1991 Honda CRX DX
1992–1995 Honda Civic LSi Hatch/Saloon (European Market)
1992–1995 Honda Civic DXi Hatch/Saloon (European Market)
1990–1995 Honda Concerto (European Market)
D15B
D15B VTEC
D15B 3-Stage VTEC
D15B2
I'm building a mini me right now in my 90 EF (d15b1) and am wondering, do I need a new wiring harness to run the P28 manual ECU or can I just wire in the Vtec?
many many write ups for this, buy the obd1 conversion harness and it will come with pigtails to run to all of the plugs and sensor's the obd0 does not have.
